Saltar al contenido principal
Reset Bluetooth Module or Factory Reset All Connected Apple Devices
Qué necesitas
Resumen del Video
  1. Reset Bluetooth Module or Factory Reset All Connected Apple Devices, Reset Bluetooth Module or Factory Reset All Connected Apple Devices: paso 1, imagen 1 de 3 Reset Bluetooth Module or Factory Reset All Connected Apple Devices, Reset Bluetooth Module or Factory Reset All Connected Apple Devices: paso 1, imagen 2 de 3 Reset Bluetooth Module or Factory Reset All Connected Apple Devices, Reset Bluetooth Module or Factory Reset All Connected Apple Devices: paso 1, imagen 3 de 3
    • First enable the Bluetooth Icon in the Menu Bar
    • Click the Launchpad icon in the Dock, and then navigate to "System Preferences" - "Bluetooth".
    • Click the checkbox next to “Show Bluetooth in Menu Bar” to enable it.
  2. Reset Bluetooth Module or Factory Reset All Connected Apple Devices: paso 2, imagen 1 de 3 Reset Bluetooth Module or Factory Reset All Connected Apple Devices: paso 2, imagen 2 de 3 Reset Bluetooth Module or Factory Reset All Connected Apple Devices: paso 2, imagen 3 de 3
    • Press and hold the Shift + Option keys on your Mac's keyboard and click the Bluetooth symbol in the top-right corner of the macOS menu bar.
    • Locate the revealed Debug submenu and hover your mouse cursor over it.
    • If you have problem with a connected Bluetooth device you can reset the Bluetooth module entirely from the Debug menu. This will wipe the Bluetooth configuration, reset the Bluetooth hardware, and disconnect any connected Bluetooth devices.
    • If you want to fix a problem with connected Apple device then try the second menu. It works only the device is connected an only for Apple devices!
Conclusión
3 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,368 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,468 Guías creadas
3 comentarios
Hi, wenn ich Shift drücke und das BT Symbol klicke kommt das normale Menü (BT An/Aus, Geräte-Übersicht, Einstellungen), wenn ich Opt (mit oder ohne Shift) drücke und auf das BT Symbol klicke kommt ein erweitertes Menü (BT An/Aus, Name, Adresse, Version, Geräte-Details, Einstellungen), aber einen Debug-Eintrag gibt es unter keinen Umständen (MacOS 12.2.1).
Wo ist das Debug Menü?
Martin Hans - Contestar
brauche ebenfalls eine antwort!
Hias Major -
Ab macOS Monterey und später geht das so:
Öffnen Sie die Suche (CMD+Spacebar drücken)
Geben Sie Terminal in das Suchfeld ein und öffnen Sie das Terminal
Geben Sie folgenden Befehl in die Kommandozeile ein: sudo pkill bluetoothd
Drücken Sie Enter, geben Sie das Passwort des Administrator-Kontos ein.
Starten Sie den Mac neu
Hinweis: Für diesen Trick benötigen Sie Administratorrechte.
Gernot Schauer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 31
Ultimos 7 días: 332
Ultimos 30 días: 1,297
Todo El Tiempo: 35,323
