Saltar al contenido principal
Introducción
When a zipper pull breaks, or the slider simply wears out, you don’t need to replace the entire zipper. Just replace the zipper slider. This is a quick repair that can make the difference between a zipper that doesn’t work at all and one that works like it’s brand new. Determine the size of your replacement slider by looking on the bottom of your existing slider.
For replacement parts or further assistance, contact Patagonia Customer Service.
Resumen del Video
  1. Locate the top of the zipper on the side with the slider. Peel back any fabric that is covering the zipper stop. Peel back any fabric that is covering the zipper stop.
    • Locate the top of the zipper on the side with the slider.
    • Peel back any fabric that is covering the zipper stop.
  2. Use end nippers to cut the stop. Be sure to only cut the plastic or metal stop. You do not want to damage the webbing behind the zipper.
    • Use end nippers to cut the stop.
    • Be sure to only cut the plastic or metal stop. You do not want to damage the webbing behind the zipper.
  3. Carefully remove any remaining pieces of the stop using tweezers.
    • Carefully remove any remaining pieces of the stop using tweezers.
  4. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  5. Slide the damaged zipper slider up and off of the zipper. Slide the damaged zipper slider up and off of the zipper. Slide the damaged zipper slider up and off of the zipper.
    • Slide the damaged zipper slider up and off of the zipper.
  6. Slide the replacement slider onto the zipper. You may need to tug a little to get it past where the old stop was.
    • Slide the replacement slider onto the zipper.
    • You may need to tug a little to get it past where the old stop was.
    • Make sure that your zipper slider is facing the correct way (right-side up) when you place it onto the zipper.
  7. Grab a new zipper stop. Insert the teeth into the webbing in the same place where the old stop was located.
    • Grab a new zipper stop.
    • Insert the teeth into the webbing in the same place where the old stop was located.
  8. Use pliers to bend the metal top of the zipper stop around the edge of the webbing, poking the single tooth on the stop through the backside of the webbing. Crimp the stop into place. Crimp the stop into place.
    • Use pliers to bend the metal top of the zipper stop around the edge of the webbing, poking the single tooth on the stop through the backside of the webbing.
    • Crimp the stop into place.
Linea de Meta
12 personas más completaron esta guía.
Brittany McCrigler
Miembro Desde 05/03/12
82,093 Reputación
132 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
99 Miembros
9,293 Guías creadas
Where do I get the zipper stop????
Jason Heimink - Contestar
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
bbehrhorst - Contestar
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
kasten39828 - Contestar
AWESOME! Thanks for the pointers - I’m ready for tomorrow’s powder day!!!!
Jenny - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 15
Últimos 7 Días: 79
Últimos 30 Días: 270
Todo El Tiempo: 72,097
