Introducción
You will need to remove the scanner tray before replacing the printer carriage. You can see a guide for this under Removing Scanner Tray.
After this step is completed you are now ready to follow the steps in order to replace the printer carriage.
Herramientas
Partes
Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
Press down on the two plastic hinges to remove the upper portion of printer.
To unplug the speaker wire, grasp the plastic plug on the end of the speaker wire then gently pull the plug away from the printer until removed.
Rotate the printer so the paper tray is facing towards you.
Gently lift the scanner tray up and away from the printer.
Press the gray plastic tabs inward toward to release the tabs from the printer.
Returning to the back of the printer, remove the scanner from the back hinges.
Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
Remove printer carriage cover by unscrewing four black coarse thread T-10 torx screws marked with red circles.
You have now successfully replaced your printer carriage for the Photosmart All In One Printer Scanner.
Follow these instructions in reverse order to reassemble your device.
3 personas más completaron esta guía.
