Saltar al contenido principal
Replacing the Audio Jack on a Hofner Violin Bass
Qué necesitas
  1. Replacing the Audio Jack on a Hofner Violin Bass, 1/4" output jack: paso 1, imagen 1 de 2 Replacing the Audio Jack on a Hofner Violin Bass, 1/4" output jack: paso 1, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the jack plate from the bottom corner of the guitar.
    • Place the components in your container in order to keep track of them.
  2. Replacing the Audio Jack on a Hofner Violin Bass: paso 2, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the four screws attaching the control panel to the instrument.
  3. Replacing the Audio Jack on a Hofner Violin Bass: paso 3, imagen 1 de 2 Replacing the Audio Jack on a Hofner Violin Bass: paso 3, imagen 2 de 2
    • Locate the jack if it has fallen inside the guitar.
    • Pull the jack and attached wire through the jack hole.
  4. Replacing the Audio Jack on a Hofner Violin Bass: paso 4, imagen 1 de 1
    • Proceed with soldering only when working in a well ventilated area.
    • Warning. When soldering, the tip and shaft of the soldering iron will become extremely hot. Avoid contact.
    • Using your soldering iron, melt the solder connecting the ground wire to the old jack.
  5. Replacing the Audio Jack on a Hofner Violin Bass: paso 5, imagen 1 de 3 Replacing the Audio Jack on a Hofner Violin Bass: paso 5, imagen 2 de 3 Replacing the Audio Jack on a Hofner Violin Bass: paso 5, imagen 3 de 3
    • Using your wire stripper tool, cut the end of the wire off.
    • Then, strip the wire so it looks similar to the wire in the red box.
  6. Replacing the Audio Jack on a Hofner Violin Bass: paso 6, imagen 1 de 3 Replacing the Audio Jack on a Hofner Violin Bass: paso 6, imagen 2 de 3 Replacing the Audio Jack on a Hofner Violin Bass: paso 6, imagen 3 de 3
    • Now we will prep the wire for soldering.
    • Secure the wire using the helping hands tool.
    • Heat one of the conductors with the soldering iron.
    • Maintaining contact between the iron and wire, carefully apply solder to the conductor.
    • Repeat this process for the other conductor.
  7. Replacing the Audio Jack on a Hofner Violin Bass: paso 7, imagen 1 de 2 Replacing the Audio Jack on a Hofner Violin Bass: paso 7, imagen 2 de 2
    • Next, prep the jack for soldering.
    • Secure the jack using the helping hands tool.
    • Apply the iron to the first conductor tab to heat it.
    • Now apply the solder to the heated tab.
    • Repeat this process for the second conductor tab.
  8. Replacing the Audio Jack on a Hofner Violin Bass: paso 8, imagen 1 de 3 Replacing the Audio Jack on a Hofner Violin Bass: paso 8, imagen 2 de 3 Replacing the Audio Jack on a Hofner Violin Bass: paso 8, imagen 3 de 3
    • Now we will proceed to solder the components.
    • Touch the hot wire to the hot conductor tab and heat with the soldering iron until they melt together.
    • Repeat this process, connecting the ground wire to the ground conductor tab.
  9. Replacing the Audio Jack on a Hofner Violin Bass: paso 9, imagen 1 de 3 Replacing the Audio Jack on a Hofner Violin Bass: paso 9, imagen 2 de 3 Replacing the Audio Jack on a Hofner Violin Bass: paso 9, imagen 3 de 3
    • Put the first nut on the output jack shaft.
    • Place the jack plate on the shaft.
    • Put the second nut on the shaft, tightening with a crescent wrench.
Linea de Meta
3 personas más completaron esta guía.
Bryan Newbold
Miembro Desde 10/03/17
124 Reputación
1 Guía escrita
Un comentario
What size guitar nut do you use? i need to find just the nut on its own
Corey Powell - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 44
Todo El Tiempo: 2,998
