Saltar al contenido principal
Replacing flash memory to a cisco 837 series router
Qué necesitas
  1. Replacing flash memory to a cisco 837 series router, Flash memory: paso 1, imagen 1 de 1
    • CISCO 837 Router
    • CISCO 877 Router
Conclusión
CONCLUSION
Replacing flash need a tftp server available;
Replacing flash need a copy of the IOS image;
Replacing flash need the usage of ROMMON; be sure that this is possible;
Removing the flash card and inserting it back is like replacing with a new one (IOS image will be gone, so don’t play it with ease);
use the first ethernet port to connect with the tftp server, although all 4 switch ports will work presumably because all being in the same first VLAN.
To reassemble your device, follow these instructions in reverse order and that's all.
Una persona más ha completado esta guía.
Eneider Colina
Miembro Desde 09/20/13
2,362 Reputación
9 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 1,258
