Saltar al contenido principal
Replacing an Atari Capacitor
Qué necesitas
  1. Replacing an Atari Capacitor, Atari Lynx: paso 1, imagen 1 de 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing an Atari Capacitor: paso 2, imagen 1 de 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing an Atari Capacitor: paso 3, imagen 1 de 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing an Atari Capacitor: paso 4, imagen 1 de 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing an Atari Capacitor, C10 Capacitor: paso 5, imagen 1 de 2 Replacing an Atari Capacitor, C10 Capacitor: paso 5, imagen 2 de 2
    • Desolder the four aluminum tabs and for more information on soldering click here.
  6. Replacing an Atari Capacitor: paso 6, imagen 1 de 1
    • Remove the aluminum back protector to gain access to the C10 capacitor.
  7. Replacing an Atari Capacitor: paso 7, imagen 1 de 2 Replacing an Atari Capacitor: paso 7, imagen 2 de 2
    • Desolder the C10 capacitor.
Conclusión
Una persona más ha completado esta guía.
John Lopez
Miembro Desde 01/27/14
443 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 1-42, Maness Winter 2014 Miembro de Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 36
Todo El Tiempo: 4,979
