Saltar al contenido principal
Introducción
It doesn’t happen often, but when a wheel on your Patagonia Wheeled Luggage blows out, it can leave you stopped in your tracks. Fortunately, installing a replacement wheel is quick and only requires a single hex screwdriver.
For replacement parts or further assistance, contact Patagonia Customer Service.
Herramientas
Partes
No se especificaron partes.
  1. Lay the bag down, with the problem wheel facing you.
    • Lay the bag down, with the problem wheel facing you.
    • Zipping the bag closed will keep it from flopping about as you work.
  2. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  3. Using a hex 4.0 screwdriver, remove the threaded bolt in the center of of the wheel. This is the screw closest to the ground when the bag is upright. Remove the bolt by pulling it straight out of the hole. Remove the bolt by pulling it straight out of the hole.
    • Using a hex 4.0 screwdriver, remove the threaded bolt in the center of of the wheel. This is the screw closest to the ground when the bag is upright.
    • Remove the bolt by pulling it straight out of the hole.
  4. Using one hand to lift and support the bag, take the wheel in your other hand. Pull the wheel out of its casing. Removing the wheel may take a little force, do not be afraid to give it a tug.
    • Using one hand to lift and support the bag, take the wheel in your other hand. Pull the wheel out of its casing.
    • Removing the wheel may take a little force, do not be afraid to give it a tug.
    • To install your replacement wheel, follow these steps in reverse order with your new wheel.
Linea de Meta
4 personas más completaron esta guía.
Brittany McCrigler
Miembro Desde 05/03/12
81,656 Reputación
132 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
101 Miembros
8,693 Guías creadas
What do you do when the nut inside the wheel housing comes loose? I can hear it rolling around in the housing. The bolt has nothing to screw back into. Is there any way to take the housing off? It looks to be held on by rivets. I'm guessing that's not a good sign.
Derek Emanuel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 17
Últimos 30 Días: 104
Todo El Tiempo: 4,401
