Saltar al contenido principal
Replacing a Sprinkler Extension
Qué necesitas
  1. Replacing a Sprinkler Extension, Sprinkler Extension: paso 1, imagen 1 de 1
    • Dig a one foot wide hole around the broken sprinkler extension down to the pipe fitting.
    • The pipe fitting is usually about one foot underground.
  2. Replacing a Sprinkler Extension: paso 2, imagen 1 de 1
    • Dig around the pipe fitting with a trowel to provide clear access.
  3. Replacing a Sprinkler Extension: paso 3, imagen 1 de 1
    • Clean the area around the fitting with water until the fitting is mostly free of dirt.
  4. Replacing a Sprinkler Extension: paso 4, imagen 1 de 2 Replacing a Sprinkler Extension: paso 4, imagen 2 de 2
    • Unscrew the sprinkler extension from the pipe fitting.
    • Once the extension is removed, water may come out of the open pipe fitting.
  5. Replacing a Sprinkler Extension: paso 5, imagen 1 de 1
    • Screw the new sprinkler extension in securely.
  6. Replacing a Sprinkler Extension: paso 6, imagen 1 de 2 Replacing a Sprinkler Extension: paso 6, imagen 2 de 2
    • Test the sprinkler to ensure that there are no leaks.
    • Refill the hole tightly.
Conclusión
If you have completed the steps successfully you should have a fully functioning sprinkler extension.
Abagayle Serreyn
Miembro Desde 09/11/15
111 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 12
Todo El Tiempo: 802
