Saltar al contenido principal
Replacing a Baseball Bat Grip
Qué necesitas
  1. Replacing a Baseball Bat Grip, Baseball Bat Grip: paso 1, imagen 1 de 3 Replacing a Baseball Bat Grip, Baseball Bat Grip: paso 1, imagen 2 de 3 Replacing a Baseball Bat Grip, Baseball Bat Grip: paso 1, imagen 3 de 3
    • Place the bat on a firm surface with the grip hanging off the edge.
    • Draw a line on the top of the old grip using a marker.
    • Practice caution when using the utility knife.
    • Use the utility knife to cut the tape where you made your mark.
    • Peel off the old grip.
    • Some bats may have an under layer of wrap that will require extra peeling to remove.
  2. Replacing a Baseball Bat Grip: paso 2, imagen 1 de 2 Replacing a Baseball Bat Grip: paso 2, imagen 2 de 2
    • Put on gloves and place the paper towels under the bat handle to catch the excess spilled residue cleaner.
    • Apply the residue cleaner to the handle.
    • Scrub off the residue with a rag.
  3. Replacing a Baseball Bat Grip: paso 3, imagen 1 de 3 Replacing a Baseball Bat Grip: paso 3, imagen 2 de 3 Replacing a Baseball Bat Grip: paso 3, imagen 3 de 3
    • Sit in a chair and hold the bat in-between your legs with the knob facing upwards.
    • Take the pre-wrap, begin at the knob of the bat and wrap downward in a spiraling motion toward the mark.
    • When applying the pre-wrap, be sure to keep it evenly layered as it will quickly get thicker when doubled.
    • Stop applying the prewrap at the marked line.
  4. Replacing a Baseball Bat Grip: paso 4, imagen 1 de 3 Replacing a Baseball Bat Grip: paso 4, imagen 2 de 3 Replacing a Baseball Bat Grip: paso 4, imagen 3 de 3
    • Hold the bat in the same position used for applying the pre-wrap.
    • Apply the electrical tape over the previous wrap using the same motion as before.
    • Be sure to evenly layer the tape to have a smooth wrap all the way down the handle.
  5. Replacing a Baseball Bat Grip: paso 5, imagen 1 de 2 Replacing a Baseball Bat Grip: paso 5, imagen 2 de 2
    • Apply a small piece of electrical tape at the beginning and end of the wrap to fasten it to the bat.
    • Now that your new grip is complete, you're ready to play ball!
Linea de Meta
9 personas más completaron esta guía.
Matthew McNabb
Miembro Desde 09/11/15
164 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 50
Ultimos 30 días: 315
Todo El Tiempo: 63,237
