Saltar al contenido principal
Replacing VuPoint DC-ST210-VP View Finder
Qué necesitas
  1. Replacing VuPoint DC-ST210-VP View Finder, Turn Off/Remove Batteries: paso 1, imagen 1 de 1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: paso 2, imagen 1 de 3 Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: paso 2, imagen 2 de 3 Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: paso 2, imagen 3 de 3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. Replacing VuPoint DC-ST210-VP View Finder, Pry Backplate Off: paso 3, imagen 1 de 2 Replacing VuPoint DC-ST210-VP View Finder, Pry Backplate Off: paso 3, imagen 2 de 2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. Replacing VuPoint DC-ST210-VP View Finder, Remove View Finder: paso 4, imagen 1 de 1
    • Use fingers or tweezers to gently lift view finder out of socket.
    • Clean with general lens cleaner and microfiber fabric as necessary and replace.
Conclusión
Dorey Chiu
Miembro Desde 10/26/14
1 Reputación
1 Guía escrita
Equipo
Baylor, Team 8-15, Williams Fall 2014 Miembro de Baylor, Team 8-15, Williams Fall 2014
BU-WILLIAMS-F14S8G15
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 16
Todo El Tiempo: 328
