Saltar al contenido principal
Replacing Sonos Play 1 Power and Volume switch board.
Qué necesitas
  1. Replacing Sonos Play 1 Power and Volume switch board., Exterior Screen: paso 1, imagen 1 de 2 Replacing Sonos Play 1 Power and Volume switch board., Exterior Screen: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
    • Once you pry open one end, use precision tweezers to remove rubber footing.
  2. Replacing Sonos Play 1 Power and Volume switch board.: paso 2, imagen 1 de 2 Replacing Sonos Play 1 Power and Volume switch board.: paso 2, imagen 2 de 2
    • Using a metal spudger, pry open a corner of the adhesive tape.
    • Use precision tweezers to remove the adhesive tape.
  3. Replacing Sonos Play 1 Power and Volume switch board.: paso 3, imagen 1 de 2 Replacing Sonos Play 1 Power and Volume switch board.: paso 3, imagen 2 de 2
    • Remove the four 10 mm Torx security #10 screws that hold the base together.
    • Remove the base by lifting it vertically away from the bulk of the device.
  4. Replacing Sonos Play 1 Power and Volume switch board.: paso 4, imagen 1 de 2 Replacing Sonos Play 1 Power and Volume switch board.: paso 4, imagen 2 de 2
    • Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
    • Using precision tweezers, remove the metal bracket.
  5. Replacing Sonos Play 1 Power and Volume switch board.: paso 5, imagen 1 de 1
    • Remove the exterior screen by lifting it away from the bulk of the device.
  6. Replacing Sonos Play 1 Power and Volume switch board., Sonos Play 1 Top Cover Disassembly: paso 6, imagen 1 de 1
    • Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
  7. Replacing Sonos Play 1 Power and Volume switch board.: paso 7, imagen 1 de 3 Replacing Sonos Play 1 Power and Volume switch board.: paso 7, imagen 2 de 3 Replacing Sonos Play 1 Power and Volume switch board.: paso 7, imagen 3 de 3
    • Using a plastic opening tool, pry open the top cap containing the power and volume button.
    • Vertically remove the top cap.
    • Be sure to not jerk the top cap when removing , as to not damage the cable linking the switchboard to the motherboard.
  8. Replacing Sonos Play 1 Power and Volume switch board.: paso 8, imagen 1 de 2 Replacing Sonos Play 1 Power and Volume switch board.: paso 8, imagen 2 de 2
    • Using a plastic opening tool, pry open the circuit flap.
    • Once flap is loosened, use your hand to remove the circuit wire.
  9. Replacing Sonos Play 1 Power and Volume switch board., Power and Volume Switch Board: paso 9, imagen 1 de 1
    • Using a screwdriver with a Torx T6 bit, remove the four highlighted 7mm screws.
    • Using you fingers remove the protective plastic plate covering the device.
  10. Replacing Sonos Play 1 Power and Volume switch board.: paso 10, imagen 1 de 2 Replacing Sonos Play 1 Power and Volume switch board.: paso 10, imagen 2 de 2
    • Using your fingers remove the plastic cover plate securing the switchboard.
    • Using your fingers, remove the power/volume switch board.
Conclusión
4 personas más completaron esta guía.
Patty
Miembro Desde 09/01/15
453 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 8-4, Eyestone Fall 2015 Miembro de USF Tampa, Team 8-4, Eyestone Fall 2015
USFT-EYESTONE-F15S8G4
4 Miembros
16 Guías creadas
9 comentarios
Where can I get the replacement power button?
Teresa Rosales - Contestar
I would like to know as well
hung pham - Contestar
Dear Patty
Where can I buy the switchboard?
Thanks in advance. :-)
/Kenneth
Kenneth - Contestar
Same quesion here from DK
Lars Jürgensen - Contestar
where can i find board
craigmdyer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 78
Todo El Tiempo: 8,736
