Saltar al contenido principal
Introducción
The circuit board is the component of the phone that allows communication between all of the inputs and outputs within the phone in order to perform tasks that the user requires.
  1. Make sure the phone is turned off by pressing the power off button to ensure no data is lost.
    • Make sure the phone is turned off by pressing the power off button to ensure no data is lost.
    • Remove the back battery cover by sliding it downward and pushing simultaneously.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Using either your thumb or the opening tools, remove the battery by prying the battery out in the direction of the arrow.
    • Using either your thumb or the opening tools, remove the battery by prying the battery out in the direction of the arrow.
    • If removing battery is for the replacement of a new battery make sure to properly dispose of the old battery at a recycling center.
  3. Remove the rubber inserts from the screw holes using the black metal tweezers.  This is done by inserting the tip of the metal tweezers down around the plastic insert. Remove the rubber inserts from the screw holes using the black metal tweezers.  This is done by inserting the tip of the metal tweezers down around the plastic insert.
    • Remove the rubber inserts from the screw holes using the black metal tweezers. This is done by inserting the tip of the metal tweezers down around the plastic insert.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Remove the 3.1mm long, Phillips #00 screws (Qty: 4)  from the corners. This is done by turning the screwdriver counter clockwise using little torque. This is done by turning the screwdriver counter clockwise using little torque.
    • Remove the 3.1mm long, Phillips #00 screws (Qty: 4) from the corners.
    • This is done by turning the screwdriver counter clockwise using little torque.
  6. Separate the phone's front case from the back case. There is an intermediate decorative outlay around the front cases perimeter. This should be removed as well. There is an intermediate decorative outlay around the front cases perimeter. This should be removed as well.
    • Separate the phone's front case from the back case.
    • There is an intermediate decorative outlay around the front cases perimeter. This should be removed as well.
  7. Remove volume slider button by using the tweezers to pry it out.
    • Remove volume slider button by using the tweezers to pry it out.
    • The volume slider button may fall out during the seperation of the front and back cases, this is ok.
  8. Using the opening tools, separate the circuit board from the inside of the back case by prying between the circuit board and the case as shown. The last picture is a view of the back of the circuit board. The last picture is a view of the back of the circuit board.
    • Using the opening tools, separate the circuit board from the inside of the back case by prying between the circuit board and the case as shown.
    • The last picture is a view of the back of the circuit board.
Conclusión
John Bender
Miembro Desde 26/03/14
822 Reputación
8 Guías creadas
Equipo
Clemson, Team 6-5, Benson Spring 2014 Miembro de Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 140
