Saltar al contenido principal
Replacing Samsung Galaxy S4 SIM Card
Qué necesitas
  1. Replacing Samsung Galaxy S4 SIM Card, Rear Case: paso 1, imagen 1 de 2 Replacing Samsung Galaxy S4 SIM Card, Rear Case: paso 1, imagen 2 de 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Replacing Samsung Galaxy S4 SIM Card: paso 2, imagen 1 de 3 Replacing Samsung Galaxy S4 SIM Card: paso 2, imagen 2 de 3 Replacing Samsung Galaxy S4 SIM Card: paso 2, imagen 3 de 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: paso 3, imagen 1 de 3 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: paso 3, imagen 2 de 3 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: paso 3, imagen 3 de 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  4. Replacing Samsung Galaxy S4 SIM Card, Battery: paso 4, imagen 1 de 3 Replacing Samsung Galaxy S4 SIM Card, Battery: paso 4, imagen 2 de 3 Replacing Samsung Galaxy S4 SIM Card, Battery: paso 4, imagen 3 de 3
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  5. Replacing Samsung Galaxy S4 SIM Card, SIM Card: paso 5, imagen 1 de 3 Replacing Samsung Galaxy S4 SIM Card, SIM Card: paso 5, imagen 2 de 3 Replacing Samsung Galaxy S4 SIM Card, SIM Card: paso 5, imagen 3 de 3
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
Conclusión
78 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
465,762 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
3 comentarios
Can you take one sim card slot out one galaxy s4 and put it in another or do u have to buy a new one
marius williams - Contestar
Somethings wrong with sim card start shut out since July 5 evening and today July 6 three times
humeston23 - Contestar
Removing sim card tray?
G M Chadwick - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 70
Ultimos 30 días: 305
Todo El Tiempo: 245,758
