1. Before disassembling your phone, be sure it is powered off. To remove the back cover press the two "buttons". Remove the battery.
    • Before disassembling your phone, be sure it is powered off.
    • To remove the back cover press the two "buttons".
    • Remove the battery.
  2. Remove the three 3mm black screws on the top of the phone. Remove the two 5mm screws.
    • Remove the three 3mm black screws on the top of the phone.
    • Remove the two 5mm screws.
    • Loosen these two screws at the bottom of the phone.
    • Probably these screws will not come out from their home, no matter. It is only important to unscrew them completely.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. With a plastic opening tool remove the little piece of plastic in the bottom of of the phone. The two corners marked are VERY SLENDER, when removing the plastic be very careful. Otherwise you will break them. To remove the logic board assembly push from the rear of the phone.
    • With a plastic opening tool remove the little piece of plastic in the bottom of of the phone.
    • The two corners marked are VERY SLENDER, when removing the plastic be very careful. Otherwise you will break them.
    • To remove the logic board assembly push from the rear of the phone.
  5. Remove the keyboard with a plastic opening tool. Remove the keyboard with a plastic opening tool.
    • Remove the keyboard with a plastic opening tool.
Conclusión
11 personas más completaron esta guía.
Matteo Moro
Miembro Desde 21/02/13
476 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 10
Todo El Tiempo: 4,274
