Saltar al contenido principal
Replacing Nokia Classic 2600c-2b Faceplate
Qué necesitas
  1. Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: paso 1, imagen 1 de 2 Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: paso 1, imagen 2 de 2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Replacing Nokia Classic 2600c-2b Faceplate: paso 2, imagen 1 de 1
    • Remove the back cover to expose the battery.
  3. Replacing Nokia Classic 2600c-2b Faceplate: paso 3, imagen 1 de 2 Replacing Nokia Classic 2600c-2b Faceplate: paso 3, imagen 2 de 2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
  4. Replacing Nokia Classic 2600c-2b Faceplate: paso 4, imagen 1 de 2 Replacing Nokia Classic 2600c-2b Faceplate: paso 4, imagen 2 de 2
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. Replacing Nokia Classic 2600c-2b Faceplate: paso 5, imagen 1 de 1
    • Remove the faceplate with the number pad attached.
  6. Replacing Nokia Classic 2600c-2b Faceplate: paso 6, imagen 1 de 1
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
    • Apply new faceplate.
    • Follow the instructions in reverse order to reassemble the phone.
Conclusión
Ian VanZandt
Miembro Desde 02/14/12
654 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 384
