Introducción
This is a step by step guide to removing the keyboard cover of an IBM ThinkPad 560z. The keyboard cover is most commonly removed to facilitate the cleaning or replacement of the keyboard.
Remove the 7 mm Philip screws.
  • Remove the 7 mm Philip screws.
  • Remove the 10 mm Philip screws.
  • Remove the 14 mm Philip screw.
Agregar Comentario
Open the flap on the left hand side.
  • Open the flap on the left hand side.
Agregar Comentario
  • Insert the iPod opening tools between the right and left sides of the latch.
  • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
Agregar Comentario
  • Open the flap on the right side.
Agregar Comentario
  • Insert the iPod opening tools towards the right side of the latch.
  • Gently pry the right side out to release the top cover.
Agregar Comentario
  • Lift the keyboard slowly.
  • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
Agregar Comentario
  • Use your fingers or a spudger to detach the connector.
Agregar Comentario
  • Carefully lift and remove the keyboard.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 26-27, Regan Spring 2010 Miembro de Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Miembros
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 31
Todo El Tiempo: 1,498
