Saltar al contenido principal
Replacing Creative Zen X-Fi Button Input Chip Part 1
Qué necesitas
  1. Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: paso 1, imagen 1 de 3 Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: paso 1, imagen 2 de 3 Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: paso 1, imagen 3 de 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Button Input Chip Part 1, Rubber Button Cover: paso 2, imagen 1 de 1
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Button Input Chip Part 1, Button Input Chip Part 1: paso 3, imagen 1 de 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Button Input Chip Part 1, Button Input Chip: paso 4, imagen 1 de 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
Conclusión
Westley Courchene
Miembro Desde 01/13/15
3,389 Reputación
14 Guías creadas
Equipo
USF Tampa, Team 1-1, Remmell Fall 2015 Miembro de USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 331
