Saltar al contenido principal
Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle
Qué necesitas
  1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle, Cog and lockring: paso 1, imagen 1 de 1
    • Remove the 9.5mm bolts on the rear wheel with an adjustable wrench. There is a bolt on each side of the wheel.
  2. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: paso 2, imagen 1 de 3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: paso 2, imagen 2 de 3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: paso 2, imagen 3 de 3
    • Loosen the 4mm by 50.8mm chain tension screw with a hex key. There is a screw on each side of the wheel.
  3. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: paso 3, imagen 1 de 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: paso 3, imagen 2 de 2
    • Remove the chain from the rear wheel cog. Remove the rear wheel from the frame of the bike.
  4. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: paso 4, imagen 1 de 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: paso 4, imagen 2 de 2
    • Remove the lockring on the back tire using a lockring wrench. To loosen the lockring twist the wrench clockwise.
  5. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: paso 5, imagen 1 de 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: paso 5, imagen 2 de 2
    • Loosen the cog using a chain whip and adjustable pliers. Rap the chain whip around the cog. Push the chain whip handle down so that the cog twists counterclockwise.
    • It will take a lot of force to loosen the cog.
  6. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: paso 6, imagen 1 de 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: paso 6, imagen 2 de 2
    • Remove the cog the rest of the way with your hand. Replace with a new cog.
Linea de Meta
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 54
Todo El Tiempo: 3,919
