Saltar al contenido principal
Replacement of Hardware on a Crossbody bag
Qué necesitas
  1. Replacement of Hardware on a Crossbody bag, Hardware on a Crossbody bag: paso 1, imagen 1 de 2 Replacement of Hardware on a Crossbody bag, Hardware on a Crossbody bag: paso 1, imagen 2 de 2
    • Remove the old stitching with the seam ripper blade.
    • Use the seam ripper blade carefully as it is very sharp.
  2. Replacement of Hardware on a Crossbody bag: paso 2, imagen 1 de 2 Replacement of Hardware on a Crossbody bag: paso 2, imagen 2 de 2
    • Remove the previous hardware from the strap.
  3. Replacement of Hardware on a Crossbody bag: paso 3, imagen 1 de 1
    • Measure, and ensure the new hardware fits.
    • Place the new hardware through the strap.
  4. Replacement of Hardware on a Crossbody bag: paso 4, imagen 1 de 2 Replacement of Hardware on a Crossbody bag: paso 4, imagen 2 de 2
    • Use the needle and thread to stitch the new hardware into place.
    • Using the adequate needle for the material you need is essential, as some materials may be thicker and need a larger needle.
    • Use needle and thread carefully, as the needle can be sharp.
  5. Replacement of Hardware on a Crossbody bag: paso 5, imagen 1 de 1
    • Verify the stitching is secure by hanging the crossbody bag.
Linea de Meta
Una persona más ha completado esta guía.
joanna
Miembro Desde 02/20/24
122 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 120
