Saltar al contenido principal
Replace "Wings" Without Breaking Open a Magsafe Charger Technique
Qué necesitas
  1. Replace "Wings" Without Breaking Open a Magsafe Charger Technique, Replace "Wings" Without Breaking Open a Magsafe Charger Technique: paso 1, imagen 1 de 1
    • Use the pliers to scratch a groove wide enough for the pin to travel in to the hole where the wings pin will fit.
    • The trick is not to make it to deep so the pin can easily come back out of the hole. Start of shallow and go deeper if required.
  2. Replace "Wings" Without Breaking Open a Magsafe Charger Technique: paso 2, imagen 1 de 2 Replace "Wings" Without Breaking Open a Magsafe Charger Technique: paso 2, imagen 2 de 2
    • Insert one side of the wings pin into its hole at an angle.
    • Now, Line up the other pin with the groove and push slide it until the pin clips back into it's hole. You may need to make the groove slightly deeper if it doesn't want to go in, as we don't want to break the pin off! The tighter the fit the better. The wing will snap back into its hole and be back to normal functionality.
  3. Replace "Wings" Without Breaking Open a Magsafe Charger Technique: paso 3, imagen 1 de 1
    • The wings should now be in place as working as intended.
Linea de Meta
Una persona más ha completado esta guía.
livfe
Miembro Desde 02/21/24
2,039 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 141
