Introducción
Los cables pueden estar sujetos a ángulos extremos durante la carga, lo que provoca que el revestimiento exterior se afloje, rasgue y, en última instancia, exponga su cableado.
Partes
No se especificaron partes.
Ubique el área deshilachada o expuesta del cable Lightning.
Para volver a armar su dispositivo, siga estas instrucciones en orden inverso.
4 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
83%
¡ Miguel nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
6 comentarios
Thank you for taking the time to post your pictures and the steps to repair a lightening cord. I plan to do this repair, and also, apply heat shrink to the other end BEFORE that one frays. Thanks!!
I have cables that do not work anymore due to the fraying at the lightning port end. Are there instructions on how to fix this?
The wiring is too intricate, Christine. It’s not worth the time it would take, IMO.
Dave -
Does this work with plastic straws instead of heat shrink?
Plastic straws cause several issues: it will be difficult to push the Lightning connector through, they won’t shrink as easily or uniformly compared to shrink tubing, and they’re rigid so there will be a hard edge at the end, likely creating a strain point where the cable will fray. Heat shrink tubing is readily available at hardware stores and it’s not expensive.
