Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Introducción
This guide will outline how take apart your Proline strap lock and replace/repair the spring. I created this guide because my strap lock fell apart. I also had to replace the spring myself because the mechanism would not lock. This is not a guide to install the strap lock.. This document assumes you already have the strap lock installed on your strap and guitar.
Herramientas
No se especificaron herramientas.
  1. To take apart the strap lock, take the black ball cap and turn it counterclockwise. After you unscrew the ball cap, pull on the other side of the locking mechanism (opposite to the ball cap) to remove the spring and bar. Unlock your strap lock from the guitar before attempting this step.
    • To take apart the strap lock, take the black ball cap and turn it counterclockwise.
    • After you unscrew the ball cap, pull on the other side of the locking mechanism (opposite to the ball cap) to remove the spring and bar.
    • Unlock your strap lock from the guitar before attempting this step.
  2. You should have these two parts removed from the rest of the lock mechanism. If you do not have the spring or your spring is broken, you can get the spring described in the conclusion.
    • You should have these two parts removed from the rest of the lock mechanism.
    • If you do not have the spring or your spring is broken, you can get the spring described in the conclusion.
    • In a pinch: a spring from some pens, cut to length, can act as the spring in your strap lock.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. To put on the spring, insert it onto the bar. If your strap lock was not locking even though it had the spring, you can increase your springs effectiveness by stretching it out a moderate amount.
    • To put on the spring, insert it onto the bar.
    • If your strap lock was not locking even though it had the spring, you can increase your springs effectiveness by stretching it out a moderate amount.
  5. Once the spring is on, reassemble your strap lock by inserting the locking mechanism into the underside of the housing. Then, screw back on the ball cap. Then, screw back on the ball cap.
    • Once the spring is on, reassemble your strap lock by inserting the locking mechanism into the underside of the housing.
    • Then, screw back on the ball cap.
Conclusión
Your strap lock should now function well, but make sure to hand test the locking strength before using your guitar. As for the replacement spring, it is hard to buy a spring of this size individually. The dimensions of the spring are approximately as follows:
Inner Diameter: 4.5 mm (.177 in)
Outer Diameter: 5.3 mm (.209 in)
Free Length: 7.8 mm (.307 in)
As stated in step 2, if you cannot get a spring of this exact size, it is possible to cut a spring from a pen to length, and with a little stretching get it to the right dimensions.
Justin Smith
Miembro Desde 09/04/15
121 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 30-4, Green Spring 2015 Miembro de Cal Poly, Team 30-4, Green Spring 2015
CPSU-GREEN-S15S30G4
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 348
