Introducción
This guide will help you repair the buttons on the Seville Classics MSC10166 Tower Fan.
Partes
No se requieren partes.
  1. Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
    • Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
    • Do this by unscrewing from left-to-right then pull the screws out of the back of the fan
  2. Pull the front and back cover apart.
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely because it holds the wires.
    • Remove the Phillips (5-mm head) 6-mm screw that holds the circuit board to the outer shell of the fan.
    • Make sure the fan is unplugged while removing the circuit board as you may get shocked.
    • To remove the screws, unscrew in a left-to-right fashion at an angle to make sure that the wires do not get tangled.
    • Remove the top cover containing the circuit board and the wires by pulling it away from the body of the fan.
    • Remove the circuit board from the top cover. Do not touch the other side of the circuit board as you may damage circuit elements.
    • Unscrew the four screws on the top of the circuit board in a left-to-right fashion. After pull screws out of the board.
    • Next remove the two (7-mm head) 8-mm screws that attach the buttons to the top cover of the fan.
    • To do this, unscrew in an upright position and pull screw out after.
    • Remove the buttons from the top cover.
    • Wipe down any dirt on the buttons.
    • Wipe down the frame that holds the buttons.
    • Reverse the order of this guide in order to put back together the fan.
Conclusión
2 personas más completaron esta guía.
Queena Phung
Miembro Desde 26/09/12
108 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 15-46, Forte Fall 2012 Miembro de Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Miembros
6 Guías creadas
Great work but our problem is the micro switch itself, after exposing the circuit board I shorted the backside solder connections to cycle the fan on and off, everything works perfectly…..now I only need to know a part number so I can find a on/off micro switch.
any suggestions?
Thanks for any help you can provide
rickkingsbury@comcast.net
Rick - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 24
Todo El Tiempo: 1,722
