Saltar al contenido principal
Repairing and Reinforcing a Closet Rack
Qué necesitas
  1. Repairing and Reinforcing a Closet Rack, Brackets Braces C-Clamps: paso 1, imagen 1 de 1
    • Use the putty knife and spread the dry wall compound filling any holes and damage made to the wall.
  2. Repairing and Reinforcing a Closet Rack: paso 2, imagen 1 de 1
    • Allow the compound to dry off so as to reach maximum hardness.
  3. Repairing and Reinforcing a Closet Rack: paso 3, imagen 1 de 1
    • Use the 100 grit sandpaper and gently sand down the areas that were puttied, thus making them flush with the wall.
    • Use safety glasses and a dust mask protecting both your lungs and eyes from any particles coming off the wall.
  4. Repairing and Reinforcing a Closet Rack: paso 4, imagen 1 de 1
    • Measure and mark where the new holes will go for the brackets, c-clamps, and braces.
    • Allow 11"-12" of space between the side wall and the first bracket and each subsequent bracket.
    • Mark holes for the c-clamps half the distance between the brackets.
    • Use a level to guarantee the rack will be straight.
  5. Repairing and Reinforcing a Closet Rack: paso 5, imagen 1 de 1
    • Use a drill with a 1/4" drill bit and make holes at each mark.
    • Use safety glasses when operating the drill, and be cautious and careful when handling the drill. Careless handling of the drill can lead to injury. For more information on how to properly handle a drill refer to this guide's introduction.
  6. Repairing and Reinforcing a Closet Rack: paso 6, imagen 1 de 1
    • Use a hammer and knock the plastic anchors into the wall where the holes were drilled.
    • Use #8 plastic anchors for best results.
  7. Repairing and Reinforcing a Closet Rack: paso 7, imagen 1 de 1
    • Use a brush and matching wall paint to coat the areas that were puttied and allow it to dry.
  8. Repairing and Reinforcing a Closet Rack: paso 8, imagen 1 de 1
    • Use a flathead screwdriver and screw the brackets into the plastic anchors.
    • Use 1-1/4" flathead screws for best results.
  9. Repairing and Reinforcing a Closet Rack: paso 9, imagen 1 de 1
    • Take the closet rack and place it onto the brackets.
  10. Repairing and Reinforcing a Closet Rack: paso 10, imagen 1 de 1
    • Use a Phillips screw driver to screw the c-clamps into the plastic anchors and reinforce the rack.
    • Use Phillips #8 1-1/4" screws for best results.
  11. Repairing and Reinforcing a Closet Rack: paso 11, imagen 1 de 1
    • Place the support braces on the rack.
    • Use a Phillips screw driver to screw them into the plastic anchors.
Linea de Meta
2 personas más completaron esta guía.
Bojan Krtinic
Miembro Desde 05/12/20
247 Reputación
1 Guía escrita
Equipo
Un comentario
Just a question what if you wanted to install a heavier more solid longer rod?
Chris M - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 72
Ultimos 30 días: 362
Todo El Tiempo: 7,609
