Saltar al contenido principal
Repairing a Stuck Flint Wheel on a Zippo Lighter
Qué necesitas
  1. Repairing a Stuck Flint Wheel on a Zippo Lighter, Repairing a Stuck Flint Wheel on a Zippo Lighter: paso 1, imagen 1 de 1
    • Open your Zippo lighter and take the inside component out of the shell simply by pulling it out.
    • Be careful of the fluid that already might be in the lighter, it might leak out.
  2. Repairing a Stuck Flint Wheel on a Zippo Lighter: paso 2, imagen 1 de 1
    • Flip the lighter to face the bottom of the unit and locate the brass colored screw.
  3. Repairing a Stuck Flint Wheel on a Zippo Lighter: paso 3, imagen 1 de 3 Repairing a Stuck Flint Wheel on a Zippo Lighter: paso 3, imagen 2 de 3 Repairing a Stuck Flint Wheel on a Zippo Lighter: paso 3, imagen 3 de 3
    • Loosen the brass screw with the flat head screwdriver
    • Unscrew the rest of the brass screw using your hand.
    • Unscrew the brass screw until it comes off and the spring beneath shows but do not take the spring all the way out.
  4. Repairing a Stuck Flint Wheel on a Zippo Lighter: paso 4, imagen 1 de 1
    • Pull the brass screw and spring out about a centimeter or two to unhinge the steel rod located beneath the flint wheel so that the rod and the wheel are not touching.
    • If necessary, tap the unit to unhinge the steel rod
  5. Repairing a Stuck Flint Wheel on a Zippo Lighter: paso 5, imagen 1 de 1
    • Follow the steps backwards to reassemble the unit and check to see if the flint wheel is unstuck.
Conclusión
You have now fixed your flint wheel! Enjoy your Zippo Lighter!
32 personas más completaron esta guía.
Joseph Yoo
Miembro Desde 04/09/15
983 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 28-3, Green Spring 2015 Miembro de Cal Poly, Team 28-3, Green Spring 2015
CPSU-GREEN-S15S28G3
4 Miembros
8 Guías creadas
29 comentarios
This made the problem even worse. The flint wheel is now unstuck but it can't make any sparks whatsoever.
Nabiel Wahedi - Contestar
me too it will not work i did the same and now it wont make sparks
cool kid -
Did you change the flint aswell? Change the flint and put it back together, if it won’t turn after changing the flint then loosen the spring again.
Bret lauk -
You need to replace the flint itself in that case.
jayanthkumarak - Contestar
Wonderful instructions! AND IT WORKED! Thank you.
John Heard - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 31
Ultimos 7 días: 246
Ultimos 30 días: 1,136
Todo El Tiempo: 145,107
