Saltar al contenido principal
Repairing a Broken or Loose Paper Towel Hanger
Qué necesitas
  1. Repairing a Broken or Loose Paper Towel Hanger, Repairing a Broken or Loose Paper Towel Hanger: paso 1, imagen 1 de 1
    • Detach the paper towel hanger from where it is attached.
    • Place it on a flat surface under sufficient light.
  2. Repairing a Broken or Loose Paper Towel Hanger: paso 2, imagen 1 de 3 Repairing a Broken or Loose Paper Towel Hanger: paso 2, imagen 2 de 3 Repairing a Broken or Loose Paper Towel Hanger: paso 2, imagen 3 de 3
    • Inspect the paper towel hanger for loose components.
    • Identify the screw that is making the paper towel loose.
  3. Repairing a Broken or Loose Paper Towel Hanger: paso 3, imagen 1 de 3 Repairing a Broken or Loose Paper Towel Hanger: paso 3, imagen 2 de 3 Repairing a Broken or Loose Paper Towel Hanger: paso 3, imagen 3 de 3
    • Take a screwdriver with a flat head to remove the loose screw.
    • Insert the screwdriver into the loose screw and rotate anti-clockwise to remove the loose screw.
  4. Repairing a Broken or Loose Paper Towel Hanger: paso 4, imagen 1 de 3 Repairing a Broken or Loose Paper Towel Hanger: paso 4, imagen 2 de 3 Repairing a Broken or Loose Paper Towel Hanger: paso 4, imagen 3 de 3
    • Get a replacement screw of the same size and insert it into the area where the old screw was.
    • Line both parts of the paper towel hanger up and secure the new screw with the 3 mm Flathead screwdriver until it's snug.
  5. Repairing a Broken or Loose Paper Towel Hanger: paso 5, imagen 1 de 3 Repairing a Broken or Loose Paper Towel Hanger: paso 5, imagen 2 de 3 Repairing a Broken or Loose Paper Towel Hanger: paso 5, imagen 3 de 3
    • Check to see if the paper towel hanger is now firm and secure.
    • Reattach the paper towel hanger to the wall.
Conclusión
In conclusion, this 'Paper Towel Hanger Repair Guide' empowers you to address a common household issue efficiently and safely. By following these steps and using the recommended tools, you can restore your hanger's functionality and ensure peace of mind.
Nziza Ngango
Miembro Desde 09/08/23
121 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 134
