Saltar al contenido principal
Repairing a Broken 3-Prong Bodycord for a Fencing Sword
Qué necesitas
  1. Repairing a Broken 3-Prong Bodycord for a Fencing Sword, Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 1, imagen 1 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword, Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 1, imagen 2 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword, Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 1, imagen 3 de 3
    • Remove the three bolts from the clamshell using a 4mm screwdriver.
    • The clam shell is the hard plastic that protects the internal wiring of the prongs.
    • During reassembly, remember to replace the nuts into their respective holes if they fell out during disassembly.
  2. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 2, imagen 1 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 2, imagen 2 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 2, imagen 3 de 3
    • Remove the top piece of the clamshell.
    • When reassembling, run the wires within the grooves to prevent pinching. If the wires are pinched, they can become damaged.
  3. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 3, imagen 1 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 3, imagen 2 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 3, imagen 3 de 3
    • Mark the wires with a marker in unique patterns to remember their order.
    • In this case, a solid line marks the wire that leads to the prong that is on the outside and near to the middle prong. A dashed line marks the wire leading to the prong that is far from the middle prong.
  4. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 4, imagen 1 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 4, imagen 2 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 4, imagen 3 de 3
    • Lift the wires and prongs out of the clamshell.
  5. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 5, imagen 1 de 2 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 5, imagen 2 de 2
    • Pull the shrink wrap down the cord.
    • During reassembly, remember to place the shrink wrap partly into the clamshell.
  6. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 6, imagen 1 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 6, imagen 2 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 6, imagen 3 de 3
    • Be careful to cut all three wires to the same length.
    • Cut the wires below the break point.
    • Usually the break point is at the place where the wires enter the clamshell.
    • Start by cutting small amounts at a time; if you did not cut below the break point, you may cut more of the wire as needed.
  7. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 7, imagen 1 de 2 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 7, imagen 2 de 2
    • Loosen the grub screws on each prong using a 2mm screwdriver.
    • You can remove the screws. However, it is easier to just loosen them for reassembly.
  8. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 8, imagen 1 de 2 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 8, imagen 2 de 2
    • Remove the wires from the prongs using fingers or needle nose pliers.
    • Set the prongs aside.
    • If pulling straight out is difficult, try a gentle twisting motion inline with the prong.
  9. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 9, imagen 1 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 9, imagen 2 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 9, imagen 3 de 3
    • Peel the wires of the cord apart about 1" (2cm).
    • Use the part of the wire that you cut off as a reference for how far to peel the wires apart.
  10. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 10, imagen 1 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 10, imagen 2 de 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 10, imagen 3 de 3
    • Strip the wires, about 1/4", or 5 mm, from the end.
    • Stripping the wires is removing the plastic insulation to expose the inner metal conductor.
    • Repeat for each wire.
  11. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 11, imagen 1 de 2 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: paso 11, imagen 2 de 2
    • Twist the loose wire strands together.
    • This step facilitates reinsertion of the wires into the prongs.
Conclusión
To reassemble your bodycord, follow steps 1-8 in reverse order, skipping steps 3 and 6.
To keep your bodycord in working order longer, remember to always pull it out of the sockets by holding onto the plastic, not the wires.
Una persona más ha completado esta guía.
Aidan Fox-Tierney
Miembro Desde 02/20/20
205 Reputación
1 Guía escrita
Equipo
UC Davis, Team S2-G6, Andersen Winter 2020 Miembro de UC Davis, Team S2-G6, Andersen Winter 2020
UCD-ANDERSEN-W20S2G6
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 447
