Saltar al contenido principal
Repairing Toyota Sienna air filter vacuum connector
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Repairing Toyota Sienna air filter vacuum connector, Repairing Toyota Sienna air filter vacuum connector: paso 1, imagen 1 de 1
    • 2008 Toyota Sienna airfilter with broken plastic vacuum connector thanks to a reckless oil change facility.
  2. Repairing Toyota Sienna air filter vacuum connector: paso 2, imagen 1 de 1
    • Remove cover for the vehicle and carefully saw off the rest of the broken connector so it is flush with the cover and will be easier to drill out.
  3. Repairing Toyota Sienna air filter vacuum connector: paso 3, imagen 1 de 1
    • Drill out the old remaining connector with a 9/32 inch drill bit. ** you must use a 9/32 only so that the new metal connector with fit snug.**
  4. Repairing Toyota Sienna air filter vacuum connector: paso 4, imagen 1 de 2 Repairing Toyota Sienna air filter vacuum connector: paso 4, imagen 2 de 2
    • Insert new metal connector with a little loctite glue using a small box wrench.
  5. Repairing Toyota Sienna air filter vacuum connector: paso 5, imagen 1 de 1
    • Replace airfilter (new one if needed) and re-attach vacuum hoses to housing in car. Pat self on the back for saving $400.
Conclusión
To reassemble your device, follow these instructions.
6 personas más completaron esta guía.
broadws
Miembro Desde 09/23/12
228 Reputación
1 Guía escrita
3 comentarios
Good luck finding the fitting! I tried three auto parts stores (including ones whose websites falsely said they had them in stock), and finally settled for an adapter at Lowes. The threaded side was about half an inch but I made it work. I'm still disgusted that the dang vacuum fitting was so flimsy to begin with.
Jesus - Contestar
Part was out of stock for a while. Now available for $9.25
broadws -
Thank you for helping me save some serious $$$. I was going to update this with photos, but since I ended up using a different fitting from Lowe's (addressing Jesus's comment), I decided that the details were sufficiently different to merit being a different guide. See it at Repairing Toyota Sienna Air Filter Vacuum Connector.
Steven Paradise - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 2,857
