Saltar al contenido principal
Repairing Sony Xperia L Volume Control Button
Qué necesitas
  1. Repairing Sony Xperia L Volume Control Button, Open the phone case: paso 1, imagen 1 de 3 Repairing Sony Xperia L Volume Control Button, Open the phone case: paso 1, imagen 2 de 3 Repairing Sony Xperia L Volume Control Button, Open the phone case: paso 1, imagen 3 de 3
    • The Xperia L model
    • Gently open the phone case.
    • The phone body, back case and the detached volume control button.
  2. Repairing Sony Xperia L Volume Control Button, Adjust the plastic notches using the plastic opening tools.: paso 2, imagen 1 de 2 Repairing Sony Xperia L Volume Control Button, Adjust the plastic notches using the plastic opening tools.: paso 2, imagen 2 de 2
    • Using the plastic opening tools in the iFixit kit, pull up the flattened plastic notches that will hold the volume control button in place.
    • You can see the notches on the back case and the holes in the volume control button that snap fit in them.
  3. Repairing Sony Xperia L Volume Control Button, Place the button and snap it to the back case using the raised notches.: paso 3, imagen 1 de 2 Repairing Sony Xperia L Volume Control Button, Place the button and snap it to the back case using the raised notches.: paso 3, imagen 2 de 2
    • Place the volume control button back in the slot.
    • Adjust the holes on the button in a way that they snap to the raised notches on the back panel.
    • Press down the raised plastic notches using the back of the plastic opening tool from the kit.
  4. Repairing Sony Xperia L Volume Control Button, Snap the back case to the phone body.: paso 4, imagen 1 de 3 Repairing Sony Xperia L Volume Control Button, Snap the back case to the phone body.: paso 4, imagen 2 de 3 Repairing Sony Xperia L Volume Control Button, Snap the back case to the phone body.: paso 4, imagen 3 de 3
    • The volume control button is now attached in its slot.
    • Reassemble the phone back by snapping the back case to the phone body.
    • The volume control/zoom button is good to use!
Conclusión
2 personas más completaron esta guía.
Ruchita
Miembro Desde 10/22/15
73 Reputación
1 Guía escrita
Equipo
PIRL Gadget Garage Miembro de PIRL Gadget Garage
Community
9 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 2,574
