Introducción
This guide assumes you have a reasonable understanding of soldering and desoldering techniques. You will be able to remove the power supply board, locate and examine the likely faulty capacitors. This guide is accurate for the LA40R81BD model however there are many similar models that experience similar issues so you may find it useful in repairing other model Samsung TV's
Qué necesitas
Using a Philips driver remove the 18 screws from the rear panel.
Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
Remove the 7 connectors from the board
Remove the 7 screws from the board
Lift the main board away from the chassis ensuring you don's snag or catch any of the cables.
Inspect all electrolytic capacitors on the power supply board and replace any that are bulging or leaking.
On my board there were 2ea 2200uf capacitors that were bulging.
Remove the old capacitors ensuring you don't overheat or damage the copper pads/tracks on the circuit board
In my case I also replaced the 1000uF capacitor
18 personas más completaron esta guía.
13 comentarios
would it be possible to replace the 2200uF capacitors with a larger size? this issue has occurred already on this TV and again on another of the same model. Thanks.
Higher voltage rated and better quality caps are what you need, don't change the value of teh capacitor though.
Richdave -
Hello, I have the blinking red lights when I try to turn on my Samsung lcd tv. I checked the capacitors and they seem to be fine except a smaller 16v 12mm capacitor is slightly bulging(not broken or leaking yet). Would that be enough to cause this? And should I just replace it?
Thank you!
