1. Before disassembly, make sure that the device is unplugged.
    • Before disassembly, make sure that the device is unplugged.
    • Unscrew the two 17.83 mm black screws located on the handle.
  2. Separate the shell from the main component.
    • Separate the shell from the main component.
    • Make sure that the each piece is free from debris.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Continue to pull the components apart. For reassembly, put the silver encasing on before the the black cover. For reassembly, put the silver encasing on before the the black cover.
    • Continue to pull the components apart.
    • For reassembly, put the silver encasing on before the the black cover.
  5. Locate the switches in the handle of the device.
    • Locate the switches in the handle of the device.
  6. Set the multimeter to 200 ACV.
    • Set the multimeter to 200 ACV.
  7. Bring the probes toward each switch to test for continuity.
    • Bring the probes toward each switch to test for continuity.
    • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
    • If the meter stays at a finite number, the circuit is open and the switch needs to be replaced.
    • To replace faulty switch, cut the wires and solder the wires back on to the new switch.
Conclusión
Jessica Leyva
Miembro Desde 18/09/12
107 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 1-5, Propen Fall 2012 Miembro de Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 11
Todo El Tiempo: 891
