Saltar al contenido principal
Repairing Quasar Microwave Fan
Qué necesitas
  1. Repairing Quasar Microwave Fan, Disassembling Quasar Microwave Outer Cover: paso 1, imagen 1 de 1
    • Disconnect the power supply cord from the outlet.
  2. Repairing Quasar Microwave Fan: paso 2, imagen 1 de 2 Repairing Quasar Microwave Fan: paso 2, imagen 2 de 2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Repairing Quasar Microwave Fan: paso 3, imagen 1 de 2 Repairing Quasar Microwave Fan: paso 3, imagen 2 de 2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Repairing Quasar Microwave Fan: paso 4, imagen 1 de 3 Repairing Quasar Microwave Fan: paso 4, imagen 2 de 3 Repairing Quasar Microwave Fan: paso 4, imagen 3 de 3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
  5. Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: paso 5, imagen 1 de 2 Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: paso 5, imagen 2 de 2
    • Locate the fan in the newly exposed interior.
    • Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
    • If the fan does not spin freely, locate what is jamming the fan and remove it.
  6. Repairing Quasar Microwave Fan: paso 6, imagen 1 de 1
    • If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
    • In order to work properly, there should be two wires going in and out of the fan. If you are missing either of these wires, locate the loose wire/s and connect them.
Conclusión
Una persona más ha completado esta guía.
Melanie
Miembro Desde 09/26/12
107 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 2-12, Propen Fall 2012 Miembro de Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 1,543
