Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
How to manually advance a stuck gear train.
Partes
No se especificaron partes.
  1. Move film door slide on the left side of camera forward. Pull film door open.
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Locate small silver gear in top left corner of film bay.
    • Locate small silver gear in top left corner of film bay.
  3. Using a plastic opening tool, rotate gear downward until jam is cleared.
    • Using a plastic opening tool, rotate gear downward until jam is cleared.
Conclusión
5 personas más completaron esta guía.
Matthew Lessig
Miembro Desde 20/01/10
63 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 3-18, Maness Winter 2010 Miembro de Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
4 Miembros
4 Guías creadas
How do you know if the jam is cleared ? I have the same camera but the problem with mine is the shutter button. Every time I press the red and black one it won't make the noise or spit out the film unless I go one button behind. Although when I do that the photo comes out black. I think the two buttons or supposed to be together so when you press the red and black button the one behind it moves in sync. I really need help on fixing it and I'm not sure if what I said made any sense but I need help.
Tiffany - Contestar
I have this very same problem…You explained it perfectly, however, I can’t figure out how to fix it. Please someone help us!
Jordan Brown -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 7,286
