Saltar al contenido principal
Repairing Oster 6344 Toaster Lever
Qué necesitas
  1. Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: paso 1, imagen 1 de 3 Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: paso 1, imagen 2 de 3 Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: paso 1, imagen 3 de 3
    • Assure the toaster is unplugged.
  2. Repairing Oster 6344 Toaster Lever: paso 2, imagen 1 de 2 Repairing Oster 6344 Toaster Lever: paso 2, imagen 2 de 2
    • Look down into the bread slots and assure that the metal tongues are not bent or crooked.
    • If the metal tongues are bent use the pliers to straighten them.
    • Plug your toaster back in and test it to see if the lever stays down.
  3. Repairing Oster 6344 Toaster Lever: paso 5, imagen 1 de 1
    • (Optional): To clean the toaster, make sure it is unplugged, empty the crumb tray and then clean out all visible residue.
    • Note: Compressed air, wooden skewers, and slightly damp, lint free cloths are most helpful when cleaning your toaster.
    • Be sure that the toaster is completely dry from cleaning before you reassemble it.
Conclusión
Daniel
Miembro Desde 07/13/13
109 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 1,632
