Saltar al contenido principal
Repairing Nokia Lumia 520 Power Button
Qué necesitas
  1. Repairing Nokia Lumia 520 Power Button, Repairing Nokia Lumia 520 Power Button: paso 1, imagen 1 de 1
    • Remove the back cover from the phone.
    • Take a bus ticket or anything else that has a thickness of 0.5-0.6 mm.
    • Cut the ticket to form a triangle.
    • Insert the triangle in the gap between the button and the chassis.
    • Cut the part of the ticket that is out of the chassis.
    • Now with a paper clip tests if it works.
    • If it works remount the back cover. If i doesn't work probably the problem is the button and not the contact and you need to replace it.
Conclusión
6 personas más completaron esta guía.
keroro90
Miembro Desde 08/07/14
213 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,843
