Saltar al contenido principal
Repairing Nintendo 64 Controller Joystick Replacement
Qué necesitas
  1. Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: paso 1, imagen 1 de 3 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: paso 1, imagen 2 de 3 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: paso 1, imagen 3 de 3
    • Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
    • Remove the 2 #00 Phillips screws from the expansion slot
    • Remove the rear housing and set aside.
  2. Repairing Nintendo 64 Controller Joystick Replacement: paso 2, imagen 1 de 3 Repairing Nintendo 64 Controller Joystick Replacement: paso 2, imagen 2 de 3 Repairing Nintendo 64 Controller Joystick Replacement: paso 2, imagen 3 de 3
    • Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly.
    • Remove the 3 #00 Phillips screws holding the joystick assembly in place.
  3. Repairing Nintendo 64 Controller Joystick Replacement: paso 3, imagen 1 de 3 Repairing Nintendo 64 Controller Joystick Replacement: paso 3, imagen 2 de 3 Repairing Nintendo 64 Controller Joystick Replacement: paso 3, imagen 3 de 3
    • Disconnect the joystick data cable and remove the old joystick.
    • To install your new joystick, simply follow these instructions in reverse.
Conclusión
Test out your controller! It should be feeling like new.
33 personas más completaron esta guía.
Zillatron
Miembro Desde 08/28/12
1,511 Reputación
1 Guía escrita
2 comentarios
If you don't line up the z button accurately it can be tricky getting the case back on.
Rainer De Temple - Contestar
I have a couple thumbstick replacements that do not have the connector. They are from Sodial, and I was wondering if there was a way that they can be easily connected.
derocher1 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 45
Ultimos 30 días: 184
Todo El Tiempo: 44,262
