Introducción
I had a problem with my autofocus, and i could not find the answer. Therefore i investigated further and found out what to do. This i have wrote in this guide.
Qué necesitas
The problem is that the autofocus can not adjust correctly. There can be more than one solution.
1. Try forcing the lens to rotate a fraction of a inch. This will sometimes help the problem. Or simply move the switch from M to A on the lens.
2. Try to switching to a single of the 11 auto focus points. Then try if there are specific points that are the problem.
This is done by selecting in the menu of your camera to the points. Then focusing on a single object with a background far away. Try focusing on the object then on the background. If this is possible the autofocus point is fine.
3. If all auto focus points are fine, try updating the firmware or cleaning the sensors inside the camera behind the mirror. If a one or more points are out of order, also try cleaning the sensors behind the mirror.
4. Detatch the lens from the camera, by applying pressure on the release button and twisting the lens so it can be released. See picture
5. Set the camera selection wheel to manual (M), see picture
6. Turn the camera on, and start the liveView format. This will flip op the mirror inside the camera.
Take a dry can blower. Or if in lack, use an empty plastic bottle, without moisture inside, and use it to blow on the autofocus sensors.
They are located at the bottom under the mirror. NOTE Do not blow with your mouth, small amount of moisture will hit the CCD also located here.
Turn the camera off
Reattach the lens. Push the lens, white point to white point and turn the lens in place.
This worked for me, hope it also helped you ;)
Hope you could use this information
27 personas más completaron esta guía.
19 comentarios
wow! good tip, AF appeared broken on my D3100, detach and reattach lens did fix it !!
My camera fell on the concrete floor 2 times within 10min..thanks to my little devil..the autofocus wasn't working. I was hopeless and thought of contacting nikon service center and the I searched for some repair tips and came across this page..wow. ...it worked for me as well..thank you so much..you saved me a few good bucks for sure..more than that I'm having a trip after a week and wasn't hopeful to get it back..but I'm a happy man now and I'm noy mad at my little angel now :)
Hi Mithles Shrivas
Happy to know that it worked :) I know the problem with the small ones, have 3 my self :)
have a nice day :)
Yes!! Thank you so much. The center point of our autofocus wasn't working, and I was worried that the camera would need expensive repair. This did the trick instantly. You just made my day!
