Saltar al contenido principal
Repairing Nikon D3100 Autofocus
Qué necesitas
  1. Repairing Nikon D3100 Autofocus, Repairing Nikon D3100 Autofocus: paso 1, imagen 1 de 3 Repairing Nikon D3100 Autofocus, Repairing Nikon D3100 Autofocus: paso 1, imagen 2 de 3 Repairing Nikon D3100 Autofocus, Repairing Nikon D3100 Autofocus: paso 1, imagen 3 de 3
    • The problem is that the autofocus can not adjust correctly. There can be more than one solution.
    • 1. Try forcing the lens to rotate a fraction of a inch. This will sometimes help the problem. Or simply move the switch from M to A on the lens.
    • 2. Try to switching to a single of the 11 auto focus points. Then try if there are specific points that are the problem.
    • This is done by selecting in the menu of your camera to the points. Then focusing on a single object with a background far away. Try focusing on the object then on the background. If this is possible the autofocus point is fine.
    • 3. If all auto focus points are fine, try updating the firmware or cleaning the sensors inside the camera behind the mirror. If a one or more points are out of order, also try cleaning the sensors behind the mirror.
    • 4. Detatch the lens from the camera, by applying pressure on the release button and twisting the lens so it can be released. See picture
    • 5. Set the camera selection wheel to manual (M), see picture
    • 6. Turn the camera on, and start the liveView format. This will flip op the mirror inside the camera.
  2. Repairing Nikon D3100 Autofocus: paso 2, imagen 1 de 1
    • Take a dry can blower. Or if in lack, use an empty plastic bottle, without moisture inside, and use it to blow on the autofocus sensors.
    • They are located at the bottom under the mirror. NOTE Do not blow with your mouth, small amount of moisture will hit the CCD also located here.
    • Turn the camera off
    • Reattach the lens. Push the lens, white point to white point and turn the lens in place.
    • This worked for me, hope it also helped you ;)
Conclusión
Hope you could use this information
27 personas más completaron esta guía.
Lasse Lorenzen
Miembro Desde 02/19/13
866 Reputación
2 Guías creadas
19 comentarios
wow! good tip, AF appeared broken on my D3100, detach and reattach lens did fix it !!
coleman corrigan - Contestar
My camera fell on the concrete floor 2 times within 10min..thanks to my little devil..the autofocus wasn't working. I was hopeless and thought of contacting nikon service center and the I searched for some repair tips and came across this page..wow. ...it worked for me as well..thank you so much..you saved me a few good bucks for sure..more than that I'm having a trip after a week and wasn't hopeful to get it back..but I'm a happy man now and I'm noy mad at my little angel now :)
Mithlesh Shrivas - Contestar
Hi Mithles Shrivas
Happy to know that it worked :) I know the problem with the small ones, have 3 my self :)
have a nice day :)
Lasse Lorenzen -
Yes!! Thank you so much. The center point of our autofocus wasn't working, and I was worried that the camera would need expensive repair. This did the trick instantly. You just made my day!
Tom Hallman - Contestar
My manual focus does not even work? I guess I have to have it repaired? It just stopped working one day.
Kolby - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 53
Ultimos 30 días: 196
Todo El Tiempo: 76,619
