Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Repairing Minolta Dimage Xt Lens Cover
Qué necesitas
    1. Repairing Minolta Dimage Xt Lens Cover, Casing: paso 1, imagen 1 de 3 Repairing Minolta Dimage Xt Lens Cover, Casing: paso 1, imagen 2 de 3 Repairing Minolta Dimage Xt Lens Cover, Casing: paso 1, imagen 3 de 3
      • Locate and remove the silver screws on each side of the camera.
      • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
      Pregunta a FixBot
      Agregar Comentario
    2. Repairing Minolta Dimage Xt Lens Cover: paso 2, imagen 1 de 3 Repairing Minolta Dimage Xt Lens Cover: paso 2, imagen 2 de 3 Repairing Minolta Dimage Xt Lens Cover: paso 2, imagen 3 de 3
      • Then, carefully pry apart the front and back outer casing away from the internal components.
      • Be aware of the ribbon wire that will disconnect when the casing is detached.
      Pregunta a FixBot
      Agregar Comentario
    1. Repairing Minolta Dimage Xt Lens Cover, Lens Cover: paso 3, imagen 1 de 1
      • Place the internal electronics face-up. Look at the side with the flash turned towards you.
      • The lens cover is a small sheet of metal that rests directly infront of the lens when the camera is turned off.
      • Check to see if the spring action arm (what the yellow arrow is pointing to) is attached to the lens cover with the small knob in the corner (circled in yellow).
      Pregunta a FixBot
      Agregar Comentario
    2. Repairing Minolta Dimage Xt Lens Cover: paso 4, imagen 1 de 1
      Herramienta utilizada en este paso:
      • If the arm is not attached (as shown in the previous), use tweezers to place the arm over the knob on the lens cover.
      • Inside the yellow circle, the arm is in the correct position.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Reassemble the casing by reversing steps 1 and 2.
Una persona más ha completado esta guía.
Equipo
Clemson, Team 12-4, Benson Spring 2013 Miembro de Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
Miembros de 3
84 Guías creadas
1Guía Comentario
In Bild 3 ist der gelbe Kreis falsch gesetzt: der kleine Knopf ist unten links an der Blende, wie in Bild 4 positioniert. hr
Hubert Rieping - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 51
Todo El Tiempo: 1,759
