Saltar al contenido principal
Repairing HTC Droid Incredible LCD
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Repairing HTC Droid Incredible LCD, Battery: paso 1, imagen 1 de 3 Repairing HTC Droid Incredible LCD, Battery: paso 1, imagen 2 de 3 Repairing HTC Droid Incredible LCD, Battery: paso 1, imagen 3 de 3
    • Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier.
  2. Repairing HTC Droid Incredible LCD: paso 2, imagen 1 de 2 Repairing HTC Droid Incredible LCD: paso 2, imagen 2 de 2
    • Remove battery, prying from the provided gap at the upper-right corner of the battery
  3. Repairing HTC Droid Incredible LCD, Back Panel: paso 3, imagen 1 de 2 Repairing HTC Droid Incredible LCD, Back Panel: paso 3, imagen 2 de 2
    • Depress MicroSD to eject it from the side of the case.
  4. Repairing HTC Droid Incredible LCD: paso 4, imagen 1 de 3 Repairing HTC Droid Incredible LCD: paso 4, imagen 2 de 3 Repairing HTC Droid Incredible LCD: paso 4, imagen 3 de 3
    • Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads.
  5. Repairing HTC Droid Incredible LCD: paso 5, imagen 1 de 3 Repairing HTC Droid Incredible LCD: paso 5, imagen 2 de 3 Repairing HTC Droid Incredible LCD: paso 5, imagen 3 de 3
    • Using a spudger, unclip the nine clips holding the back panel to the front panel, highlighted in included pictures.
    • Start at the top, and work clockwise, being careful not to break the clips.
    • There are, 1, 3, 2, and 3 clips on each side, respectively.
    • After the clips are disengaged, there are no cables holding the back panel in place.
  6. Repairing HTC Droid Incredible LCD, Optical Track Pad: paso 6, imagen 1 de 3 Repairing HTC Droid Incredible LCD, Optical Track Pad: paso 6, imagen 2 de 3 Repairing HTC Droid Incredible LCD, Optical Track Pad: paso 6, imagen 3 de 3
    • Use your spudger to release the jaw clip holding the Optical Track Pad cable to the logic board.
    • Remove Optical Track Pad from logic board.
  7. Repairing HTC Droid Incredible LCD, Logic Board: paso 7, imagen 1 de 1
    • Use your spudger to release the remaining clips, disconnecting the ribbon cables from the logic board.
  8. Repairing HTC Droid Incredible LCD: paso 8, imagen 1 de 2 Repairing HTC Droid Incredible LCD: paso 8, imagen 2 de 2
    • Remove 2 Phillips Screws holding the logic board to the front panel.
    • Gently lift the logic board off the front panel.
  9. Repairing HTC Droid Incredible LCD, LCD: paso 9, imagen 1 de 2 Repairing HTC Droid Incredible LCD, LCD: paso 9, imagen 2 de 2
    • Remove the two phillips screws from the top of the LCD frame.
    • Use your spudger to pry the LCD out of the frame.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 3,714
