Saltar al contenido principal
Repairing HP OfficeJet 3833 Paper Jam
Qué necesitas
  1. Repairing HP OfficeJet 3833 Paper Jam, Repairing HP OfficeJet 3833 Paper Jam: paso 1, imagen 1 de 2 Repairing HP OfficeJet 3833 Paper Jam, Repairing HP OfficeJet 3833 Paper Jam: paso 1, imagen 2 de 2
    • Remove all paper from the printer.
  2. Repairing HP OfficeJet 3833 Paper Jam: paso 2, imagen 1 de 2 Repairing HP OfficeJet 3833 Paper Jam: paso 2, imagen 2 de 2
    • Check the input tray, located in the back of the printer, for any paper remains and remove them.
  3. Repairing HP OfficeJet 3833 Paper Jam: paso 3, imagen 1 de 2 Repairing HP OfficeJet 3833 Paper Jam: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Check the input tray for any foreign objects.
    • You may need to hold down the input tray and shine a flashlight inside to have a better look.
    • Long tweezers are recommended to remove objects such as thumbnails and tacks.
  4. Repairing HP OfficeJet 3833 Paper Jam: paso 4, imagen 1 de 2 Repairing HP OfficeJet 3833 Paper Jam: paso 4, imagen 2 de 2
    • Check the output tray, located in the front of the printer, for paper remains and remove them.
  5. Repairing HP OfficeJet 3833 Paper Jam: paso 5, imagen 1 de 3 Repairing HP OfficeJet 3833 Paper Jam: paso 5, imagen 2 de 3 Repairing HP OfficeJet 3833 Paper Jam: paso 5, imagen 3 de 3
    • Shut down the printer.
    • Hold down the power button until a message appears.
    • Select the Shut Down option.
    • A message will appear and the printer will turn off.
  6. Repairing HP OfficeJet 3833 Paper Jam: paso 6, imagen 1 de 2 Repairing HP OfficeJet 3833 Paper Jam: paso 6, imagen 2 de 2
    • Unplug the printer power cable from the wall outlet.
    • Remove the power cable from the back of the printer.
  7. Repairing HP OfficeJet 3833 Paper Jam: paso 7, imagen 1 de 3 Repairing HP OfficeJet 3833 Paper Jam: paso 7, imagen 2 de 3 Repairing HP OfficeJet 3833 Paper Jam: paso 7, imagen 3 de 3
    • Pull back on the front sides of the printer to remove the front panel.
    • Then pull the handle inside to remove the ink cartridge panel.
  8. Repairing HP OfficeJet 3833 Paper Jam: paso 8, imagen 1 de 2 Repairing HP OfficeJet 3833 Paper Jam: paso 8, imagen 2 de 2
    • Slide the ink cartridge to the side.
    • This step must be done carefully to prevent damage to the printer.
  9. Repairing HP OfficeJet 3833 Paper Jam: paso 9, imagen 1 de 2 Repairing HP OfficeJet 3833 Paper Jam: paso 9, imagen 2 de 2
    • Search for and remove any debris.
  10. Repairing HP OfficeJet 3833 Paper Jam: paso 10, imagen 1 de 1
    • Put the printer on its side.
    • You may need to open the top half and lay it down to prevent the printer from falling.
  11. Repairing HP OfficeJet 3833 Paper Jam: paso 11, imagen 1 de 2 Repairing HP OfficeJet 3833 Paper Jam: paso 11, imagen 2 de 2
    • Locate the cleanout door on the bottom half of the printer.
    • Open the cleanout door to remove unwanted debris.
Linea de Meta
Ivory S. Mayorga
Miembro Desde 09/16/20
193 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 40
Todo El Tiempo: 3,097
