Saltar al contenido principal
Replacing a Casio Exilim EX-Z850 Speaker
Qué necesitas
  1. Replacing a Casio Exilim EX-Z850 Speaker, Speaker: paso 1, imagen 1 de 3 Replacing a Casio Exilim EX-Z850 Speaker, Speaker: paso 1, imagen 2 de 3 Replacing a Casio Exilim EX-Z850 Speaker, Speaker: paso 1, imagen 3 de 3
    • Remove the screws on both sides and the bottom of the camera with the Phillips #00 screwdriver.
    • The bottom screws are longer than the side screw.
  2. Replacing a Casio Exilim EX-Z850 Speaker: paso 2, imagen 1 de 1
    • Gently pry apart the rear casing from the body of the camera.
    • Do not pull the casing completely away from the camera or you will damage the ribbon securing the rear casing to the contents inside the camera.
  3. Replacing a Casio Exilim EX-Z850 Speaker: paso 3, imagen 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: paso 3, imagen 2 de 2
    • Use the tweezers to gently peel the ribbon from the contents inside of the camera, leaving it connected to the rear casing.
    • Set aside rear casing.
  4. Replacing a Casio Exilim EX-Z850 Speaker: paso 4, imagen 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: paso 4, imagen 2 de 2
    • Use the tweezers to pry the LCD screen from the frame.
    • The bottom of the LCD screen is attached to the frame by black tape.
  5. Replacing a Casio Exilim EX-Z850 Speaker: paso 5, imagen 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: paso 5, imagen 2 de 2
    • Use the tweezers to flip the LCD screen to the other side.
    • The LCD screen has a ribbon on the bottom of it that is connected to the contents inside of the camera, do not pull it apart.
  6. Replacing a Casio Exilim EX-Z850 Speaker: paso 6, imagen 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: paso 6, imagen 2 de 2
    • Pry the LCD casing from the tape that is underneath it and then flip it to the opposite side to expose the contents under it.
  7. Replacing a Casio Exilim EX-Z850 Speaker: paso 7, imagen 1 de 3 Replacing a Casio Exilim EX-Z850 Speaker: paso 7, imagen 2 de 3 Replacing a Casio Exilim EX-Z850 Speaker: paso 7, imagen 3 de 3
    • Use the tweezers to flip open the connector that is holding the ribbon connected to the LCD screen in place.
    • Remove the LCD screen with the ribbon from the camera.
  8. Replacing a Casio Exilim EX-Z850 Speaker: paso 8, imagen 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: paso 8, imagen 2 de 2
    • Remove the front casing from the body of the camera.
  9. Replacing a Casio Exilim EX-Z850 Speaker: paso 9, imagen 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: paso 9, imagen 2 de 2
    • Remove two screws on the side where the battery is located using the Phillips #00 screwdriver.
    • Pull the side casing so it becomes dislocated from the top of the camera frame.
  10. Replacing a Casio Exilim EX-Z850 Speaker: paso 10, imagen 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: paso 10, imagen 2 de 2
    • On the front of the camera, near the flash flip, there is a connector holding a ribbon. Remove the ribbon from the connector.
  11. Replacing a Casio Exilim EX-Z850 Speaker: paso 11, imagen 1 de 3 Replacing a Casio Exilim EX-Z850 Speaker: paso 11, imagen 2 de 3 Replacing a Casio Exilim EX-Z850 Speaker: paso 11, imagen 3 de 3
    • Carefully remove the L shaped frame from the camera by popping the frame off the bumps and tabs located at the bottom of the camera.
    • There is a yellow and orange wire soldered onto the camera. Be careful not to disconnect them.
    • The blue box is the speaker.
  12. Replacing a Casio Exilim EX-Z850 Speaker: paso 12, imagen 1 de 1
    • Use the tweezers to remove the speaker.
Conclusión
Christian
Miembro Desde 01/28/11
320 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-38, Regan Winter 2011 Miembro de Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 2,664
