Saltar al contenido principal
Introducción
This guide will show how to replace the speaker on the Casio camera
Partes
No se especificaron partes.
  1. Remove the four screws on the side with the speaker
    • Remove the four screws on the side with the speaker
  2. Remove the four screws from the bottom of the camera.
    • Remove the four screws from the bottom of the camera.
    • Note: Bottom screws are longer than the top ones, so label accordingly for easy reassembly
  3. Remove the four screws on the side opposite of the speaker.
    • Remove the four screws on the side opposite of the speaker.
  4. Pull apart the bottom casing.
    • Pull apart the bottom casing.
  5. Remove ribbon from the rear casing. Set aside rear casing.
    • Remove ribbon from the rear casing.
    • Set aside rear casing.
  6. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  7. Use tweezers or prongs to pry the LCD screen off from the opening. Note: The bottom of the LCD screen is attached to the frame by a few pieces of black tape.
    • Use tweezers or prongs to pry the LCD screen off from the opening.
    • Note: The bottom of the LCD screen is attached to the frame by a few pieces of black tape.
  8. Lift up the LCD screen, slowly move it to the other side. Lift up the LCD screen, slowly move it to the other side.
    • Lift up the LCD screen, slowly move it to the other side.
  9. Pry off the LCD casing which is taped on to the frame. Pry off the LCD casing which is taped on to the frame.
    • Pry off the LCD casing which is taped on to the frame.
  10. Flip open the connector holding the ribbon. Pull out the LCD screen with the ribbon from the camera. Pull out the LCD screen with the ribbon from the camera.
    • Flip open the connector holding the ribbon.
    • Pull out the LCD screen with the ribbon from the camera.
  11. Pull apart the front casing. Pull apart the front casing.
    • Pull apart the front casing.
  12. Remove two screws on the side where the battery is located. Remove the lanyard loop after the screws come off.
    • Remove two screws on the side where the battery is located.
    • Remove the lanyard loop after the screws come off.
    • Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
  13. On the front of the camera near the flash flip the connector holding the ribbon. Remove the ribbon from the connector.
    • On the front of the camera near the flash flip the connector holding the ribbon.
    • Remove the ribbon from the connector.
  14. Carefully remove the L shaped frame from the camera At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab. Pop the frame off the bumps and tabs.
    • Carefully remove the L shaped frame from the camera
    • At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab.
    • Pop the frame off the bumps and tabs.
    • Note: There is a yellow and orange wire soldered onto the camera. Be careful not to pull them off.
    • The blue box is the speaker
  15. Remove the speaker with tweezers
    • Remove the speaker with tweezers
Conclusión
Christian
Miembro Desde 28/01/11
320 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-38, Regan Winter 2011 Miembro de Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,517
