Saltar al contenido principal
Introducción
Camera went completely dead - removed the front cover and found a screw loose. Replaced it and the camera worked fine. This could be a problem for others.
Partes
No se especificaron partes.
  1. Follow guide “Disassembling Canon PowerShot SD1100 IS Front and Rear Cover”
    • Follow guide “Disassembling Canon PowerShot SD1100 IS Front and Rear Cover”
  2. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  3. Check inside camera for loose screw from this location (indicated by yellow arrow). Return the screw to location and  firmly tighten it. Reposition and tighten the covers.  Problem solved!
    • Check inside camera for loose screw from this location (indicated by yellow arrow). Return the screw to location and firmly tighten it. Reposition and tighten the covers. Problem solved!
Conclusión
Una persona más ha completado esta guía.
Frank
Miembro Desde 13/04/11
25 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 704
