Saltar al contenido principal
Repairing Canon PowerShot Lens Error E-18
Qué necesitas
  1. Repairing Canon PowerShot Lens Error E-18, Repairing Canon PowerShot Lens Error E-18: paso 1, imagen 1 de 1
    • Place camera lens facing upwards on the table.
    • Press and hold down the power button.
    • Simultaneously press down the shutter button.
  2. Repairing Canon PowerShot Lens Error E-18: paso 2, imagen 1 de 1
    • Replace the batteries in the camera.
    • To open the battery cover slide the black lever on the underside of the camera and pull the cover toward the front.
    • Remove the old batteries from the camera and wait a few moments.
    • Put in a fresh set of batteries.
    • Close battery slide and power camera back on.
  3. Repairing Canon PowerShot Lens Error E-18: paso 3, imagen 1 de 1
    • Put blow dryer in the "no heat" setting prior to plugging it in.
    • Plug in and turn the blow dryer on.
    • Blow air in the gaps between the lens.
Conclusión
In conclusion, using this guide to fix the E-18 on the lens of the Canon PowerShot A80,will allow the camera to capture photos once again. To reassemble your device, follow these instructions in reverse order.
2 personas más completaron esta guía.
Tim
Miembro Desde 01/06/11
172 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 7-31, Regan Winter 2011 Miembro de Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 Miembros
12 Guías creadas
Un comentario
merci! mon appareil fonctionne à nouveau
nadia.labadi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 102
Todo El Tiempo: 5,992
