Saltar al contenido principal
Repairing Buttons on Casio fx-300ES Calculator
Qué necesitas
  1. Repairing Buttons on Casio fx-300ES Calculator, Repairing Buttons on Casio fx-300ES Calculator: paso 1, imagen 1 de 2 Repairing Buttons on Casio fx-300ES Calculator, Repairing Buttons on Casio fx-300ES Calculator: paso 1, imagen 2 de 2
    • Remove the six 5 mm screws on the back of the calculator.
  2. Repairing Buttons on Casio fx-300ES Calculator: paso 2, imagen 1 de 2 Repairing Buttons on Casio fx-300ES Calculator: paso 2, imagen 2 de 2
    • Carefully remove the back plate to reveal the circuit board and the battery.
  3. Repairing Buttons on Casio fx-300ES Calculator: paso 3, imagen 1 de 3 Repairing Buttons on Casio fx-300ES Calculator: paso 3, imagen 2 de 3 Repairing Buttons on Casio fx-300ES Calculator: paso 3, imagen 3 de 3
    • Remove the four 4 mm screws from the circuit board.
  4. Repairing Buttons on Casio fx-300ES Calculator: paso 4, imagen 1 de 1
    • Be aware of the placement of the blue, black, red, and yellow wires because they will fall out when the next step is taken.
  5. Repairing Buttons on Casio fx-300ES Calculator: paso 5, imagen 1 de 3 Repairing Buttons on Casio fx-300ES Calculator: paso 5, imagen 2 de 3 Repairing Buttons on Casio fx-300ES Calculator: paso 5, imagen 3 de 3
    • Carefully lift the circuit board while leaving the grey rubber piece face down.
    • Simply flip the circuit board and the screen over but do not remove them fully.
    • Make sure the calculator is face down.
    • Buttons are loose do not flip calculator over.
  6. Repairing Buttons on Casio fx-300ES Calculator: paso 6, imagen 1 de 3 Repairing Buttons on Casio fx-300ES Calculator: paso 6, imagen 2 de 3 Repairing Buttons on Casio fx-300ES Calculator: paso 6, imagen 3 de 3
    • Now lift the grey rubber piece off to reveal the individual buttons.
    • Buttons are loose make sure they do not come off with the rubber piece.
  7. Repairing Buttons on Casio fx-300ES Calculator: paso 7, imagen 1 de 3 Repairing Buttons on Casio fx-300ES Calculator: paso 7, imagen 2 de 3 Repairing Buttons on Casio fx-300ES Calculator: paso 7, imagen 3 de 3
    • To remove the buttons you can use your screwdriver and lightly flip them out of their individual spaces.
    • You can now access all the buttons and make any alterations needed.
  8. Repairing Buttons on Casio fx-300ES Calculator: paso 8, imagen 1 de 1
    • Refer to this picture if any buttons get misplaced or fall out.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 28-2, Green Spring 2015 Miembro de Cal Poly, Team 28-2, Green Spring 2015
CPSU-GREEN-S15S28G2
4 Miembros
2 Guías creadas
4 comentarios
Great photos make sure to replace the stock photos with those you take. Maybe retake photos with white background.
Kathryn Webb - Contestar
my answer key button not working. when i press button it shows the X10 so what can i do plzz give tips for repairing
ayush shukla - Contestar
Halp my board is stuck to the front plate sith super glue from previous owner.
[deleted] - Contestar
I repaired my Casio fx-300w, a similar calculator with similar buttons. My mother, who gave it to me, spilled coffee once when using it in her office. I got rid of the sticky coffee gunk formed nearly 12 years ago.
Matthew Yang - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 28
Ultimos 30 días: 91
Todo El Tiempo: 24,836
