Saltar al contenido principal
Introducción
The actuator failure occurs due to faulty design. Apparently replacement actuators are no better than the originals as they continue to fail. I did this to my Odyssey several years ago after both rear window actuators failed within months of each other. I have not had a single failure since applying this fix.
    • Download attached PDF.
  1. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
Conclusión
16 personas más completaron esta guía.
Documentos Adjuntos
Marvin
Miembro Desde 27/06/10
477 Reputación
1 Guía escrita
Down load didn't work...I would really like to have the answer to this question. PDF does not provide any information...if there are links inside the PDF they don't work either. The key question is how do you remove the panel that covers the Honda Odyssey Rear window actuator?....on a 2002 to be specific?
KHM - Contestar
Worked great!! I only broke 1 clip getting the panels off. That meant I paid the dealer about $1.50 instead of the $300 they wanted to fix it.
Grunt - Contestar
This mod is done to new/working actuators, correct? Not ones that have already failed.
gradh - Contestar
The mod can be done to failed or non-failed actuators. The part that fails is bypassed. It was primarily developed to repair failed actuators.
Marvin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 21
Últimos 30 Días: 125
Todo El Tiempo: 55,885
