Introducción
The actuator failure occurs due to faulty design. Apparently replacement actuators are no better than the originals as they continue to fail. I did this to my Odyssey several years ago after both rear window actuators failed within months of each other. I have not had a single failure since applying this fix.
Herramientas
16 personas más completaron esta guía.
Documentos Adjuntos
18 Comentarios
Down load didn't work...I would really like to have the answer to this question. PDF does not provide any information...if there are links inside the PDF they don't work either. The key question is how do you remove the panel that covers the Honda Odyssey Rear window actuator?....on a 2002 to be specific?
Link to Marvin's PDF: http://ifixit-documents.s3.amazonaws.com...
