Saltar al contenido principal
Repairing 1984-1989 Toyota 4Runner Idler Arm
Qué necesitas
  1. Repairing 1984-1989 Toyota 4Runner Idler Arm, Repairing 1984-1989 Toyota 4Runner Idler Arm: paso 1, imagen 1 de 1
    • First the Idler arm must be removed from the truck. Another guide has instructions to take the arm off.
  2. Repairing 1984-1989 Toyota 4Runner Idler Arm: paso 2, imagen 1 de 2 Repairing 1984-1989 Toyota 4Runner Idler Arm: paso 2, imagen 2 de 2
    • Place the arm in a vise.
    • Spray the cap with penetrating lubricant.
    • Using a screw driver, tap the idler arm bracket cap off.
    • If it will not come off easily, then check out the trouble shooting page.
  3. Repairing 1984-1989 Toyota 4Runner Idler Arm: paso 3, imagen 1 de 3 Repairing 1984-1989 Toyota 4Runner Idler Arm: paso 3, imagen 2 de 3 Repairing 1984-1989 Toyota 4Runner Idler Arm: paso 3, imagen 3 de 3
    • Using a 19 mm socket, take the nut off from inside the idler arm bracket.
    • If the arm rotates in the bracket, then it can be taken out of the vice and placed on the ground.
    • Once on the ground, your foot can be used to stop the arm from rotating and enable you to put torque on the nut.
    • Once the nut is off, the arm can be gently tapped out of the bracket.
  4. Repairing 1984-1989 Toyota 4Runner Idler Arm: paso 4, imagen 1 de 2 Repairing 1984-1989 Toyota 4Runner Idler Arm: paso 4, imagen 2 de 2
    • Remove the oil seal.
    • Remove the plastic bushings with a flat head.
    • Both bushings and oil seals should be removed and replaced.
    • Fill the bracket with MP grease and then put the arm back into the bracket.
    • Wipe off any grease that squeezes out of the bracket.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 678
