Saltar al contenido principal
Repair and Extend the Life of Weathered Wood Railing
Qué necesitas
  1. Repair and Extend the Life of Weathered Wood Railing, Repair and Extend the Life of Weathered Wood Railing: paso 1, imagen 1 de 1
    • First, you will want to prep the wood railing and surrounding area.
    • You can use a hose to rinse, followed by a cloth if needed. Let the wood dry before proceeding to next step.
  2. Repair and Extend the Life of Weathered Wood Railing: paso 2, imagen 1 de 1
    • Next, you will want to secure the wood railing and its structure.
    • Hammer any nails that are loose.
    • For missing nails, you should replace with similar nails. It doesn't matter too much what nails are being used, as you will cover it with wood filler in the next step.
  3. Repair and Extend the Life of Weathered Wood Railing: paso 3, imagen 1 de 2 Repair and Extend the Life of Weathered Wood Railing: paso 3, imagen 2 de 2
    • Fill in holes for both nails and wood imprfections/damage.
    • You can fill holes with an exterior wood filler. Simply just use your finger or a putty knife. Fill space completely. It is okay to have excess, as you will sand it in the next step.
    • Why fill in holes? Filling in holes can protect imperfections in wood where weather may decay the integrity of the wood faster. Additionally, filing in the holes provides a cleaner look when finished.
  4. Repair and Extend the Life of Weathered Wood Railing: paso 4, imagen 1 de 3 Repair and Extend the Life of Weathered Wood Railing: paso 4, imagen 2 de 3 Repair and Extend the Life of Weathered Wood Railing: paso 4, imagen 3 de 3
    • Sand the wood and the areas where you used wood filler.
    • Take your sanding paper or sanding block as shown, and sand the wood in a circular motion.
    • You do not need it perfectly smooth, but ensure any wood filler is flush with the wood itself.
  5. Repair and Extend the Life of Weathered Wood Railing: paso 5, imagen 1 de 2 Repair and Extend the Life of Weathered Wood Railing: paso 5, imagen 2 de 2
    • Once sanded, you will want to clean the entire wood railing with a damp cloth, or hose and cloth again if needed.
    • By wiping after you sand, this will remove wood particles that have been sanded away and left on the surface. Cleaning the area will yield better quality results when staining or painting.
  6. Repair and Extend the Life of Weathered Wood Railing: paso 6, imagen 1 de 2 Repair and Extend the Life of Weathered Wood Railing: paso 6, imagen 2 de 2
    • Before staining or painting, tape off any areas that need protection.
    • Areas that you may want to protect are areas where the railing meets a wall or planter box, metal hinges, or anywhere you do not want paint/stain to get onto. By taking the time now to prep for paint and stain, it will save you time in the cleanup after the project is complete.
  7. Repair and Extend the Life of Weathered Wood Railing: paso 7, imagen 1 de 2 Repair and Extend the Life of Weathered Wood Railing: paso 7, imagen 2 de 2
    • Lastly, it is time to paint or stain your railing.
    • You will want to pour your paint or stain into a paint pail. This will make it easier and more efficient when using a paint brush.
    • Take your brush and do short-to-medium strokes in the direction of the wood grain. This will provide a smooth application. Your paint strokes should go from left to right, or right to left.
    • Please note, paint and stains can be toxic. Do not consumer or ingest.
    • Paint and stains can be difficult to clean up if spilled or you get on a surface not indented to receive the paint or stain. Take your time.
    • You can always do another layer of paint or stain. It is best to apply a light coat of paint or stain first. You can always go back to areas needing better coverage if needed.
    • Once all of the wood railing has either been painted or stained, you are done! Let dry for a couple of hours before touching.
Conclusión
In conclusion, your wood railing is now protected from the elements, AND, looks amazing! For cleaning you can wipe with a damp cloth, or water hose. You can touch up the wood railing with the paint or stain if needed.
Una persona más ha completado esta guía.
Cody Baird
Miembro Desde 06/28/23
172 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 189
